MichaelB
5 years agoE-Tile TX/RX out clock constraint
I've defined a data rate in my E-Tile IP and I want to switch the data rate using the E-Tile Avalon reconfiguration interface by setting the internal PLL multiplier.
Now I have chosen the ...
- 5 years ago
Michael,
Apologize for the late reply on this. You can try to refer to the following UG to find some of the E-Tile hard IP example designs which were validated by engineering.
See if it is helpful.
KennyT_altera
5 years agoAlso, can you double check the user guide and reference design for the constrain needed?
