SSikk
6 years agoE-Tile Hard IP for Ethernet Intel FPGA IP in Quartus 19.3 tool for Stratix 10-DX Device
Our design is integrated with P-Tile PCIe with Ethernet of Datawidth 512bits. Ethernet link is up but o_tx_ready of ethernet is toggling all the time rather than being high or low for some time. .stp...
Deshi_Intel
6 years agoHI,
Thanks. I have reviewed your signal_tap result. Below is my comment.
- I can see that o_tx_ready is toggling but there is also no proper Avalon ST Tx data transaction in the signal_tap like what we had in user guide (page 102, figure 33). Are you driving data to Ethernet TX interface at all ?
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-s10-etile-hip-ethernet.pdf
- I also noticed the signal_tap result still contains PCIe signal bus. Can you share with me the signal_tap result for standalone Ethernet example design only.
As I mentioned before, there could be 3 possibility that maybe impacting the Ethernet IP behaviour and we can rule them out one by one
- Potential Quartus design issue
- May I know are you using below example design to verify the Ethernet application ? Else can you test example design and show me the signal_tap result
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-dex-s10-etile-hip-ethernet.pdf
- based on user guide guideline, there are 2 factor that can affect o_tx_ready signal
- ready latency setting and also don't send tx data packet until assertion of o_tx_lanes_stable signal
- Potential S10 device itself issue or board design or power up issue
- There is nothing much we can do about the S10 device for now but you can verify your board design first
- Are you using your own board or Intel FPGA dev kit board ?
- Typically area that you want to watch out is FPGA power, clocking and reset. Ensure you connect and power up them properly as per S10 pin connection guideline
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/stratix-10/pcg-01020.pdf
dlim
