10 years agoDynamic Partial Reconfiguration on Stratix V
Hello everyone, I want to dynamic reconfigure a partition of my design. I have followed these steps so far: a) make a revision of my project and assign the different personas for each revi...
10 years ago --- Quote Start --- Hi Onoufrios, did you already managed to convert .msf abd .sof to the partial rbf files? This is how i do within a POST_FLOW_SCRIPT_FILE:
set path "output_files"
set binaries "${path}/rbf"
file mkdir ${binaries}
set start_point x40y2
run_cmd "quartus_cpf
-p $path/${revision}.${start_point}.msf
$path/${revision}.sof
$path/${revision}.${start_point}.pmsf"
set options ""# lappend options "-o use_scrub=on"# lappend options "-o enhanced_bitstream_compression=on"# lappend options "-o bitstream_decompression_during_pr=on"
set target_file "$binaries/${revision}.${start_point}.rbf"
-c $path/${revision}.${start_point}.pmsf
${target_file}"
The PR IP has two Registers, PR_CSR and PR_DATA. - set PR_CSR to 0x1 (start single clock PR)
- copy partial rbf to if->PR_DATA register
- check PR_CSR for status
