10 years agoDynamic Partial Reconfiguration on Stratix V
Hello everyone, I want to dynamic reconfigure a partition of my design. I have followed these steps so far: a) make a revision of my project and assign the different personas for each revi...
10 years agoHi Onoufrios,
did you already managed to convert .msf abd .sof to the partial rbf files? This is how i do within a POST_FLOW_SCRIPT_FILE:
set path "output_files"
set binaries "${path}/rbf"
file mkdir ${binaries}
set start_point x40y2
run_cmd "quartus_cpf
-p $path/${revision}.${start_point}.msf
$path/${revision}.sof
$path/${revision}.${start_point}.pmsf"
set options ""
# lappend options "-o use_scrub=on"
# lappend options "-o enhanced_bitstream_compression=on"
# lappend options "-o bitstream_decompression_during_pr=on"
set target_file "$binaries/${revision}.${start_point}.rbf"
-c $path/${revision}.${start_point}.pmsf
${target_file}"
The PR IP has two Registers, PR_CSR and PR_DATA. [LIST] set PR_CSR to 0x1 (start single clock PR) [/LIST] [LIST] copy partial rbf to if->PR_DATA register [/LIST] [LIST] check PR_CSR for status [/LIST] I guess you know this document already: https://www.altera.com/en_us/pdfs/literature/ug/ug-partrecon.pdf Additionally you need at least for CycloneV an extra PR license and you have to enable PR in quartus.ini. Don't know about StratixV.
