10 years agoDuplicating Avalon ST Video Stream - Color Plane Sequencer or Avalon-ST Splitter?
I have a design right now that duplicates Avalon-ST video streams using a string of color plane sequencers and I was wondering whether there is an advantage to using the CPS over the dedicated Avalon...
9 years ago1. Do you mean just pause CVI and simply steal bytes from any of triple buff mem area of FB ? that was first that came to my mind )) Not so quality solution, but straight and simple, and believe if use DMA, it almost cant see the difference in CVO live stream.
2. The solution I like more and tried to implement, but got ”The source has a startofpacket signal of 1 bits, but the sink does not" error when connected AvST splitter into video path. I guess there some adapters are required, and to splitter's output too ? 3. Do you mean build an alternative (triple buffering) FB, with function to make frame shot (to 4th buffer to elsewhere) per CPU request ? Very attractive solution, but I have no HDL sources of original FB to study and rewrite it later. 4. I think also there should exist a solution with Avalon-ST video monitor IP, when trace system input replaced by CPU. (Sorry for offtop discussion)
