18 years agoDSPBuilder signaltap tuning
Hi, I try to check correction of data from audio codec with signaltap on 2S60 DK. How can I decrease rate of data assigns to signaltap memory in dspbuilder model. I put signaltap block before ...
18 years agoDear Anakha,
First of all thank you help. I know in advance that the codec take out the data in 32KHz Fs that mean all samples in the middle are same ZOH (zero order hold). My question is how can I cause to signaltap node assigns data to memory more slowly than clock rate in dspbuilder model. Thanks yan_w
