18 years agodsp builder not work with megawizard functions?
hello i have a problem with a project who has instanciate megawizard functions and i want to import it to dsp builder with the hdl import block. i do the compile in hdl import ,do the analysis...
17 years agoI'm not sure if my problem is related to yours.
I can compile a design, but it appears that nothing is 'working'. I get a slew of Warnings in Matlab: --- Quote Start --- Warning: Failed to locate Registered Model for S-Function 'space_demod/Clock' Warning: Failed to locate Registered Model for S-Function 'space_demod/Constant' Warning: Failed to locate Registered Model for S-Function 'space_demod/Cyclone III EP3C25 Starter Board' Warning: Failed to locate Registered Model for S-Function 'space_demod/Integrator1' Warning: Failed to locate Registered Model for S-Function 'space_demod/Parallel Adder Subtractor' Warning: Failed to locate Registered Model for S-Function 'space_demod/Signal Compiler' Warning: Failed to locate Registered Model for S-Function 'space_demod/nco_v8_0' --- Quote End --- and so on.... This is after upgrading to v8.0 sp1. --Mickey
