17 years agoDSP builder jammed
hi, every time that i click COMPILE on the Signal Compiler dialog box my simulink, matlab and other window that are related will be jammed and not responding. i couldnt figure out why and ...
17 years agoOk now can you try the following command:
alt_dspbuilder_mdl2xml <modelname> At the end of running this command, do you have a .mdlxml file? Does it hang?
