17 years agoDSP builder jammed
hi, every time that i click COMPILE on the Signal Compiler dialog box my simulink, matlab and other window that are related will be jammed and not responding. i couldnt figure out why and ...
17 years agoThe TestBench Block is used to compare the results of simulation in Simulink against Modelsim. It's in the AltLab library where you would have found the Signal Compiler Block.
