17 years agoDSP builder jammed
hi, every time that i click COMPILE on the Signal Compiler dialog box my simulink, matlab and other window that are related will be jammed and not responding. i couldnt figure out why and ...
17 years ago --- Quote Start --- I have used DSP Builder without problems in Matlab r2007b. it's the only way i see, cause your machine has just the necessary resources. --- Quote End --- so you are using the Quartus II 7.2sp3 and DSP Builder II 7.2sp3 as well? i do believe is the matlab not compatible. so if it possible if i use matlab 2007a? i think i only have installer for 2006a and 2007a. by the way, if i were to change my matlab, can i just uninstall the old one and install the new one. will this give any problem?
