17 years agoDSP Builder Installation Problem
im using matlab 7.4.0 (im not sure which version was it but i think its pretty old) with quartus ii 7.2sp3 and dsp builder ii 7.2 sp3. when install the dsp builder i have the following message appea...
17 years agobertronicom,
It sounds like you don't have the class path set up properly. At the MATLAB prompt, type: type classpath.txt At the bottom, there should be a section like: # DSPBuilder START .... # DSPBuilder END Does it exist and does it point to a file in your current DSP Builder installation?
