17 years agoDSP Builder Installation Problem
im using matlab 7.4.0 (im not sure which version was it but i think its pretty old) with quartus ii 7.2sp3 and dsp builder ii 7.2 sp3. when install the dsp builder i have the following message appea...
17 years ago --- Quote Start --- I have got Microsoft Vista Sp1 SO I had installed and running fine DSP Builder 7 with Quartus 7.2 and Matlab R2007b. Last week I tried to upgrade to the Quartus 8 and I had problems with license. Then I decided desinstalling all programs and return to the Altera suite 7.2. Now Quartus and NIOS EDS are running fine, but after installing DSP Builder over Matlab this message of error appears,
Install type is install
Adding path : c:\altera\72\quartus\dsp_builder\bin\matlab
Adding path : c:\altera\72\quartus\dsp_builder\bin\mdllibrary
DSP Builder path saved.
Creating board components
??? Undefined function or variable 'com.altera.dspbuilder.simulation.components.ComponentLibrary'.
Error in ==> c:\altera\72\quartus\dsp_builder\bin\matlab\alt_dspbuilder_createComponentLibrary.p>alt_dspbuilder_createComponentLibrary
at 24
Error in ==> setupDSPBuilderPath at 94
alt_dspbuilder_createComponentLibrary; --- Quote End --- did it work well when you initially installed the quartus 7.2 Lite?
