17 years agoDSP Builder Installation Problem
im using matlab 7.4.0 (im not sure which version was it but i think its pretty old) with quartus ii 7.2sp3 and dsp builder ii 7.2 sp3. when install the dsp builder i have the following message appea...
17 years agoThe error message "QUARTUS_ROOTDIR\dsp_builder\bin does not contain BlockInfo.dll" is produced when DSPB detects something went wrong and tries to diagnose what might be wrong with the installation. It does the following check:
blockinfoFile = fullfile(getenv('QUARTUS_ROOTDIR'), 'dsp_builder', 'bin', 'BlockInfo.dll'); file_status = exist(blockinfoFile, 'file'); if file_status ~= 3 ... error end So I'm a little confused about why it would say it couldn't find the file unless it didn't exist. Is there anything interesting about your machine/setup, I should know? Is it Windows XP or Vista? 32 bit or 64 bit? If 64 bit, is matlab 32-bit (64-bit matlab is not supported)? Do you have other versions of Quartus installed? Are these other versions on the system path?
