17 years agoDSP Builder Installation Problem
im using matlab 7.4.0 (im not sure which version was it but i think its pretty old) with quartus ii 7.2sp3 and dsp builder ii 7.2 sp3. when install the dsp builder i have the following message appea...
17 years ago --- Quote Start --- i got the following: >> sGeneric ??? MEX level2 S-function "sGeneric" must be called with at least 4 right hand arguments and for the second command, sgeneric i got the following pop up: This application has failed to start because BlockInfo.dll was not found. Re-installing the application may fix this problem --- Quote End --- Are you saying you ran the sGeneric command twice and it printed different error messages?
