17 years agoDSP Builder Installation Problem
im using matlab 7.4.0 (im not sure which version was it but i think its pretty old) with quartus ii 7.2sp3 and dsp builder ii 7.2 sp3. when install the dsp builder i have the following message appea...
17 years ago --- Quote Start --- First of all can you confirm what QUARTUS_ROOTDIR points to? Just type getenv('QUARTUS_ROOTDIR') at the MATLAB command prompt. Next up can you type "sGeneric" at the MATLAB command prompt. You should get an error (even if it's fine - since you didn't give any parameters). Please paste the error text here. And finally can you list the contents of the directory c:\altera\72sp3\quartus\dsp_builder\bin ? --- Quote End --- i got the following: >> getenv('QUARTUS_ROOTDIR') ans = c:\altera\72sp3\quartus >> sGeneric ??? MEX level2 S-function "sGeneric" must be called with at least 4 right hand arguments and for the second command, sgeneric i got the following pop up: This application has failed to start because BlockInfo.dll was not found. Re-installing the application may fix this problem then i attach the list of file i have in c:\altera\72sp3\quartus\dsp_builder\bin
