17 years agoDSP Builder Installation Problem
im using matlab 7.4.0 (im not sure which version was it but i think its pretty old) with quartus ii 7.2sp3 and dsp builder ii 7.2 sp3. when install the dsp builder i have the following message appea...
17 years agohi.i think you're right,but the compatibilitites of altera'software is not so good,also.the dspbuilder works well depends on not only itself,but also matlab,maybe ug_dspbuilder.pdf which you can download from altera.com is your good teacher,after the installation of matlab and quartus,when you install ipcore and dsp,their directory you'd better select with default.
