DSP Builder FIFO
- 2 years ago
Yes, you can import the HDL. Please use the 16.2.1. HDL Import (intel.com).
It will solve your problem.
Thank you,
Kshitij Goel
Yes, that will work as a system clock (Maximum Clock). the write clock and read clock will be your normal 1-bit signals and the inputs to it is like clocks, you want to give.
You can share your example design. I will take a look and check how it can be done as per your requirements.
Hope this helps.
Thank you,
Kshitij Goel
- Finees2 years ago
Regarding of your last comment I'm a bit confused: "Yes, that will work as a system clock (Maximum Clock). the write clock and read clock will be your normal 1-bit signals and the inputs to it is like clocks, you want to give."
Are you referring to the write and read clock signals in the FIFO when I tried to import from Verilog to the simulation block?
Finees
