DSP Builder FIFO
- 2 years ago
Yes, you can import the HDL. Please use the 16.2.1. HDL Import (intel.com).
It will solve your problem.
Thank you,
Kshitij Goel
Thank you,
Kshitij Goel
Thanks for the recommendation. This is useful for me.
I have implemented some Verilog examples and imported them with the HDL Import function and they worked.
On the other hand, I have implemented a Verilog example of a dual clock FIFO memory and tried to import it, but it gives me error:
Is there anyway to use two clocks in general in DSP? DSP builder does not provide any provision for clock to any of its components. It takes the default clock which one sets in the control block.
Thank you,
Finees
