17 years agoDSP Builder 8.0 Advanced Blockset / DSP resources
Has anyone been able to successfully specify that a given FIR filter / NCO / etc. be implemented with logic cells (instead of DSP blocks) in an advanced blockset design? From what I can tell, in the...
17 years agoOne thing you can do is open the Control block at the top of your design. There's a parameter there called Hard Multiplier Threshold which defaults to -1. Setting this to a positive number means that DSPBA will try to replace a multiplier with logic if the number of "LEs" used for it will be less than that number.
