19 years agoDoes Altera support ZBT SRAM for Stratix II devices?
I see this in Stratix I datasheet but I can't find this mentioned anywhere on their site for Stratix II? Does Stratix II support it? Up to 200 MHz? :eek:
19 years agoStratix II wasn't created with any hooks for ZBT and Altera hasn't published any analysis on supporting this. It is probably safe to say that if someone wants to do ZBT, they will have to take this risk on themselves. ZBT isn't rocket science though so if you want to take some risk you should:
Pick an implementation strategy (pins to use, etc) Create a timing methodology Explore the datasheet for key parameters Perform a timing analysis This will get you most of the way there.
