Documentation for Cyclone 10 GX core components?
Thank you!
Unfortunately, that document doesn't provide me with additional information regarding the cyclone10gx_ddio_in module being instantiated within the altera_gpio_one_bit module. The GPIO when instantiated, interfaces with an altera PHY transceiver instance on the following logical port pins:
pipe_phy_status
pipe_rx_status
pipe_rx_valid
rx_data
rx_datak
Here is a code snipped showing the actual connections:
wire [23:0] pipe_rx_phy = {1'b0,
pipe_phy_status, // 1 bit
pipe_rx_status, // 3 bits
pipe_rx_valid, // 1 bit
rx_datak, // 2 bits
rx_data // 16 bits
} /* synthesis keep */;
wire [23:0] pipe_rx_h;
wire [23:0] pipe_rx_l;
// Instantiate GPIO in DDIO register mode
mf_ddio_rx ddio_rx (
.datain (pipe_rx_phy),
.clk (local_clk),
.dataout_h (pipe_rx_h),
.dataout_l (pipe_rx_l)
where can I find additional information about the cyclone10gx_ddio_in module?
Luis
