DisplayPort Only Connects to Windows not Linux
Hi Daniel,
I presume your system setup is like below. Correct me if I am wrong
- win/linux CPU -> DP Rx -> DP Tx -> monitor
Does connecting win CPU -> monitor directly (via DP cable) works ?
Do you have S10 GX dev kit board to try out to rule out potential board setup issue ?
Have you try different brand or shorter DP cable to check for potential signal integrity concern ?
Are you using below Stratix 10 Intel FPGA DisplayPort design example ?
I believe it's not about the OS difference issue but rather on the graphic card issue
- I presume you are using different graphic card on Win and Linux machine ?
- Have you compare the spec between these 2 graphic card to find out the difference that maybe the root cause
- Have you try to play around with Nvidia graphic card setting to see if it helps ? (Like BPC setting, lower down video resolution, disable adaptive sync and etc)
- Also do you really need HBR3 (8G datarate) for 4Kp60 resolution ? Can you try change DisplayPort IP to 4G datarate channel to see if works ?
- If you are using DP example design, can you dump out the MSA log as per attached 4k support sample screenshot ?
dlim
- Deshi_Intel6 years ago
Hi Daniel,
Thanks for the clarification on dual OS boot using same graphic card. That means your hardware setup should be fine and no signal integrity concern.
In this case, I don't think sending debug log to me will be any useful anymore. The most we can prove is graphic card is not sending correct data to DP Rx in Linux OS.
- DP Rx is just a reception IP. DP Rx cannot control how DP Tx source (graphic card) transmit AUX data to DP Rx.
- Something is funny happening on Linux OS.
The direct relation that I can think of between graphic card interaction with OS would be graphic card driver.
- The easiest way will be to either upgrade or downgrade Nvidia Linux OS driver installation and hope that it fix the issue
- Or the other possibility is you configure different graphic card setting in Linux OS vs Win OS that somehow cause the failure. You may want to cross check the setting between 2 OS.
- Finally if you had confirmed the graphic card setting used in both OS is the same but video output failure still happened. Then my suggestion is you can raise this issue back to Nvidia to seek their help in understanding graphic card driver difference between Win OS and Linux OS.
dlim
- DZuck16 years ago
Hi Dlim, I have tried two different NVIDIA graphics cards in Linux (two different drivers) and neither one seems to work with the DP IP core. I have signalTap on the output of the Bitec Clkrec core (Data, HSYNC, VSYNC & VID_DE) and they do not toggle when plugged into Linux. The NVIDIA control panel says that the monitor is connected and displays how many lanes are active and at what rate. Would the AUX log show you any more information about what is going on between the IP core and the graphics card that may shed light on what is going on? Thanks, Daniel - Deshi_Intel6 years ago
Hi Daniel,
The previous MSA log file dump is meaningful if the DP link training already happened and user just need extra info like validate the BPC setting, monitor the link BER rate, check for MSA lock status and etc.
But from your issue description, looks like DP core is not transferring any data at all and somehow the link training is already stop or never started at all.
- For Aux bus transaction monitoring, I use external protocol analyzer to decode the Aux transaction to provide meaningful data result to user.
- For instance, I am using UNIGRAF DPA400 equipment to decode/debug DP AUX transaction
- https://www.unigraf.fi/product/dpa-400-displayport-aux-channel-monitor/
- Attached is sample log file for your reference. Then I can compare the passing log file vs failing log file to slowly isolate the issue
dlim
