DisplayPort at non GPU mode on Cyclone 10 GX and Quartus pro 20.1
Thank you
I understand GPU mode on/off function clearly.
I look at bitec_reconfig_alt_c10.v It doesn't have .mif file reading function.
If I need more information , I will let you know.
Thank you again
Michael
Hi
I changed non GPU and rx_phy only mode in dp_0_ example_design and added EDID memory. and Programming FPGA ( 10CX220YF672E6G) in custom board.
Windows 10 recognized new display (1920x1200, 120HZ, Attached pic1). but generated error (attached pic2).
I probed 5 inside signals
1. gxb_rx_analogreset [0] = always "1"
2. gxb_rx_digitalreset [0] = always "1"
3. gxb_rx_analogreset_ack[0] = always "0"
4. rx_analog_reconfig_req = always "0"
5. rx_reconfig_busy = always "1"
I think the digitalreset and analogreset doesn't release,
so it doesn't works transceiver configuration.
Can you recommend any solution ?
Michael
