Michael2021
5 years agoDisplayPort at non GPU mode on Cyclone 10 GX and Quartus pro 20.1
I tried to finalize design non GPU mode. doesn't provide non GPU mode example design. I can't figure it out how to connection Transceiver Native PHY Reconfiguration interface signal ( this signal i...
Deshi_Intel
5 years agoHi,
With refer to my previous post update and attached screenshot, I do see DP Rx CPU bus is removed when GPU mode is turned off in Quartus Pro v20.1
Are you seeing different result than me ?
dlim
Michael2021
5 years agoI knew I got the same result in non GPU mode on DP core. My question is not DP core. Transceiver reconfiguration connection has GPU bus.
How to connection this three files in non CPU mode ?
bitec_reconfig_alt_c10.v, xcvr_reconfig_arbiter.sv, av_native_phy_rx.ip.
and where is .mif file or no need .mif file ?
thank you
Michael
