Direct interface Bus (DIB)
Hi
I would like to generate a behavioral model of the DIB for simulation.
However, when I create a DIB IP and click on the 'Generate HDL' icon, part of the output files include gibberish instead of regular code.
Attach 1 file for example
How can I fix this?
FPGA device : 1SM21BHU2F53E2VG (startix 10)
Quartis version : 22.3.0
Thank you
Yishay
- KennyT_altera
Kindly take note that there will be a delay in replying to the forum for this case. Because we have 5 consecutive public holidays but we will try our best to address your question as soon as possible.
Instead of sending us the .txt file, do you mind sending us your *.qar files for us to investigate?
- SyafieqS
That seem to me like an encrypted file generated from PD.
Does this affect you behavior simulation of the DIB?
Let me know any concern on this.
- SyafieqS
Also,
DIB IP is only used for Intel® Stratix® 10 GX 1SG10M variant.
If you use that device, how can you access to the IP?
The IP is hidden to all devices accept s10 10m.
Let me know we can have a quick call.
- ymiler
Contributor
Hi
My FPGA belong to startix 10 GX family - as I wrote above my device is : 1SM21BHU2F53E2VG
About the simulator ( simvision -cadence) - I got error since a have encrypted files
And , sure no probelm to a quick call ( teams ? I'm Intel emploee )
Yishay
- SyafieqS
Yes sure,
But do you mind telling me how you instantiate DIB IP?
Is it directly from IP using the device mentioned?
As far as I am concern this IP is solely for 10M S10 device variant and I have double checked that using your device the IP is not available.
- ymiler
Contributor
Hi ,
Thank you for your answer
I solved the issue , I had to set my simulation tool in the “generate hdl” GUI , then Quartus creates all the simulation files
regardign your Q
-I just opened it from the Quartus IP catalog
Thank you
Yishay
- SyafieqS
Let me know if there is any other concern on this.
- ymiler
Contributor
Yes , I have other concern .
I have 2 Q about INTEL instructions regarding the DIB architecture :
Link : https://www.intel.com/content/www/us/en/docs/programmable/683142/20-2-19-3-0/reset-architecture.html
1)Quote : "you must track all the dib_ready pins from both dies to determine that both intel Stratix 10GX variants are ready for data transactions"
How can I track all the dib_ready pins from both dies ? How DIE0 get the information about “ready” flag from DIE1 ?
2)Quote : " The reset of the PL (main reset of the design _ should be released only after all the dib_ready_n from all the used dib instances are low"
Why does it relevant the reset of the PL ?
Why DIB depends to the PL ?
- SyafieqS
Hello Yishay,
I can see the concern have been addressed in the email loop. We can follow up from there.
