Sijith
2 years agoDebugging PCIe DMA transfer example design
Hi, I would like to have your continued support on this thread. Unfortunately this ticket got closed https://community.intel.com/t5/FPGA-Intellectual-Property/A-design-based-on-the-PCIe-DMA-transfe...
VenT_Altera
2 years agoHi @Sijith,
Please note that in the design example, the DMA read/write operations are initiated from the host side to the FPGA side. To initiate the DMA read/write operations from the FPGA side to the host, users will need to modify the driver. Without the proper modification, the DMA operations may not be successful. Have you made the necessary changes to the driver to suit your current application?
May I know if you need more time to provide the update?
It is advisable to keep the forum thread active, otherwise, I'll need to transition to community support. You may open a new post if you have further questions.
VenTingT
