14 years agoDe2-115 Ethernet Example
I am using the VEEK kit which uses the DE2-115 board. I have Ethernet Port 1 up and running using the web server example. I can not get Ethernet Port 0 to work. I even started with the Ethe...
13 years agoDid you get a new kit? Was your problem solved? I have nearly the same problem with my DE2-115. A reference design for a ethernet based system functions on my old board and not on my new one.
