14 years agoDe2-115 Ethernet Example
I am using the VEEK kit which uses the DE2-115 board. I have Ethernet Port 1 up and running using the web server example. I can not get Ethernet Port 0 to work. I even started with the Ethe...
14 years agoThis is a problem with their boards and timing analysis. I hAve 2 boards, one works and the other doesn't. By doesn't I mean unreliable. I sent my board back to terasic but apperantly they have to tighten the timing on the webserver example.
This is beyond me at this stage. Hope that helps stay some anxiety.
