9 years agoDE10-nano Encrypted ROM IP Content help
I have a requirement to initialize a ROM block used on the Cyclone V FPGA fabric with externally stored values. This ROM block is part of a proprietary core we're developing. The ROM data must be sto...
9 years ago --- Quote Start --- Keeping that data secure is a high priority requirement. But they also want the flexibility of having different data in a different instance of the core. It sounds like the way to go is create a secure, encrypted IP for distribution. I imagine the customer would instance this as a back box and load the encrypted IP when they build the chip. We'd have to automate creating IP cores, each having it's own special data. Anyone have a better method? --- Quote End --- Depends what you mean by 'secure'. You could have a generic FPGA image that gets distributed to all users, but you have a microSD/SD card attached to the FPGA, that only your startup code can read, that has the 'secure' keys that you distribute that is user specific. Or if it does not need to be replaceable use a separate soldered down SPI flash memory chip that has the secure data that is specific to each board (in case 'removable' storage for the data is not an option).
