18 years agoDDR/DDR2 HP compiler - multiple devices
Hi, I am trying to drive two DDR devices from one instance. I have made the settings in the wizard, so I am getting two clock pairs, 2 cke's and so on. But the ras/cas/adress signals needs to ...
18 years agoI would like the chips to operate as one. But they are mounted as separete devices on the board. (It's an old design).
The problem is to tell the IP that I need to split the command signals. It will not let you do that. Not without messing inside the controller. Which I do not have time to. regards geir
