18 years agoDDR/DDR2 HP compiler - multiple devices
Hi, I am trying to drive two DDR devices from one instance. I have made the settings in the wizard, so I am getting two clock pairs, 2 cke's and so on. But the ras/cas/adress signals needs to ...
18 years agoHello,
my understanding is, that multiple devices are configured by parameter memory chip selects in conjunction with chip selects per dimm. The Altmemphy manual (also referred by HP Controller manual regarding memory configuration details) explains the meaning of the said parameter: --- Quote Start --- Memory chip selects 1, 2, 4, or 8 The number of chip selects in your memory interface. This is the depth of your memory in terms of number of chips. --- Quote End --- As an example, when using two 1 GB Mobile SODIMM modules, I would configure Memory chip selects = 4 and Chip selects per DIMM = 2. This implies, that all memory signals except the said chip selects and clock signals would be tied together als usual. Regards, Frank
