18 years agoDDR/DDR2 HP compiler - multiple devices
Hi, I am trying to drive two DDR devices from one instance. I have made the settings in the wizard, so I am getting two clock pairs, 2 cke's and so on. But the ras/cas/adress signals needs to ...
18 years agoHi,
yes the PHY maps the command signals directly to IO primitives. The HP controller wizard does not mention no of devices. So I would need to remove the IO primitives and double the command signals output from the PHY for the signals in question: RAS/CAS/ADR//WE/BA. That looks like I will mess up all the scripts. There has to be a smooth way around this. Frank, the HP PHY will not allow you use multiple devices as far as I can see. Where should I look? I am gonna post this with Altera. G
