15 years agoDDR3 SDRAM Controller with UniPHY 11.0 Generation Failed
When I use the MegaWizard Plug-in Manager to generate my ddr2 sdram controller with UniPHY, there are some such error informations. What is wrong with it? and how can i settle down it? Thanks...
15 years agoI've also ran into this type of error (but not that exact wording) when trying to compile with a DDR controller.
In my case, it seemed to only occur when using the web edition on a part that the web edition doesn't support. I had two cases 1) Using QSYS to compile for a stratix part with the web edition and it went away when I switched to a 30 day licensed version. 2) Using Qsys with a web edition on a stratix part and it went away when switching to a part supported by the web edition. David Smith
