15 years agoDDR2 with cyclone IV E
Hi, I would like to use a ddr2 with a cyclone IV E in my design. I choose the most available ddr2 512Mb x16 at micron : MT47H32M16HR-25E. Now i have to choose an IP to manage it. "DDR2 cont...
15 years agoI did quiet the same thing:
- is it simple to set parameters in this IP / is the IP compatible with this DDR2 model I didn't have any problem. I just need to adjust the CAS lantency - I have a niosII license, does it include the DDR2 license ? You should to compile your design. If you get a file name: your_project_time_limited.sof you have to bye the license. You can buy the embedded IP pack. 2 advises (it was my errors): + You should be carefull with the routing. Track must have approcimatively the same length. + Don't forget to focus on RDN and RUP pins ! Good luck
