17 years agoDDR2 reading errors on last two words
Hi, I've some problems with my ddr2 design. I use Altera DDR2 high performance IP on pci express dev board (Stratix II GX). I build some logic around my memory controler in order to test...
17 years agoSounds to me like an unaligned memory access issue.
Check the data width of your controller, the address locations you can access are only multiples of the data width. For example, a 64-bit data width, addressing can only happen at these addresses : 0x0, 0x64, 0x128, 0x192, 0x256...etc Cheers, Thean Charn
