17 years agoDDR2 reading errors on last two words
Hi, I've some problems with my ddr2 design. I use Altera DDR2 high performance IP on pci express dev board (Stratix II GX). I build some logic around my memory controler in order to test...
17 years agoI have not use the ddr2 HP core, but i have used the ddr sdram controller. In that core ,the test_complete signal always goes high when reading is finished. It does not indicate the test is passed. pnf is short for pass no fail, 1 is passed and 0 is failed. I think it's the same for ddr2 HP controller.
If i'm correct, pnf should always be high before reading starts, I can't understand why yours is low. You may check your core for detail information.
