14 years agoDDR2 memory with ALTMEMPHY and Micron MT47H32M16HR-25E
I am having trouble setting up ddr2 memory for a micron MT47H32M16HR-25E single memory chip with Altera ALTMEMPHY with Quartus 11.1 and QSYS I have set all the timings to the data sheet from a...
14 years agoHi Socrates
Thanks for the advice I set it to half rate as you suggested and it all burst into life. I need to check now will my NIOS CPU be running at 125 MHz or 62.5MHz ( I am using the sysclk out of the ALTMEMPY to clock the system) If you could explain why you have to use half rate or point me to some online literature I would be very gratefull Still a great end to the year with a working design:D Thanks again Neil
