18 years agoDDR2 HP Controler -- need some help!
Hello, I'm trying to use DDR2 HP v8.0 controler. I've a stratix II PCIe dev board with 5 memory chips on it. Total memory is 288 Mo. I generate DDR2 HP with megawizard, native interface...
18 years agoAre you using DDR2 HP component without SOPC? Anyways, are you taking care of feedback signals from controller like rdata_valid and wdata_req signals? I guess DDR2's latency will come into picture and you will not be able to write or read anything immediately you need to wait for its latency period, I guess you should be able to read/write single data by controlling DDR2 HP component using feedback signals given.
