18 years agoDDR2 High Performance Con V7.1 SDC file difference between Stratix III and Stratix II
Hi I create a DDR2 High Performance Controller V7.1 with a stratix II device and find that the auto-generated SDC file include many constraints, such as DQ/DQS/Addr/Cmd output delay, DQ input d...
18 years agoHello,
Sorry, I can give you my advice, because I use Stratix II only. But I think you are profession in my issues, I need your help. I have some troubles with my design. I use MegaWizard in Quartus's Web edition(not create High performance Controller), to create ALTMEMPHY. It releases many files such as: *_alt_mem_phy_reconfig_sii *_alt_mem_phy_ sii alt_mem_phy_defines alt_mem_phy_sequencer.vhd *_altmem_phy_sequencer_wrapper.vo ... Module "alt_mem_phy_sequencer.vhd" is encrypted, so I can't see anything. How can I use this module? To ensure my logic is ok, I simulate them with my logic by using NCverilog 5.5. But the way ALTMEMPHY tool uses parameter is new to me. And when I run my simulation, it can not stop and print out may warnings. So you can give me your advice. I'm very impressed by ALTMEMPHY but I can't use it for a long time. Thank you in advance!
