8 years agoDDR2 Fitter(Place & Route) report errors
The FPGA is Cyclone IV EP4CE30F23C7, FBGA484-7 And ddr2 parameters are as follow: https://alteraforum.com/forum/attachment.php?attachmentid=14289&stc=1 https://www.alteraforum.com/forum/atta...
8 years agoHave you checked the pin assignments in the Memory generator (ALTMEMPHY). Make sure the pin assignments do not conflict with other pin assignments in your project/board. I guess, you also need to choose a memory vendor aka Micron/Samsung/etc from the Memory vendor list so that you are targeting the correct memory chip. Each chip has its own timing parameters so be careful in selecting the vendor and chip carefully from the supported memory list.
