18 years agoDDR2 Controller controlling 4-chips
Hello, I am new to using the DDR2 Megacore Controller and have a quick question. I have a board that has 4 DDR2 memories and has created 2-banks of memory each bank has 2-DDR2 memories. Each memory i...
18 years agoIf the two banks are intended to operate independantly, either different addresses or R/W direction, you need two separate controllers, if they are working fully parallel, you can use a single controller with double data width.
P.S.: My above answer is wrong regarding your hardware. The two banks could be operated from one controller only if they would share the address and control pins. There is no option in the controller IP to split these signals to two physical pins. So you have to use two controller instances in any case.
