18 years agoDDR2 Controller Config "local_size"
Hello, I am writing a verilog local interface that will read a block of data (131,072 64-bit word) from a fifo and use a DDR2 MegaCore function to store the data in DDR2 memory. I am looking over pag...
18 years agoHello, you mentioned something very concerning that I need to ask. I'm not using the Avalon Bus, so do you suggest I use the non-HP Controller? I looked over the documentation and I don't see a Full Rate Native Interface Mode only Half Rate, maybe need to use that mode?
