9 years agoDDR2 calibration fail using cyclone IV device
I am using cyclone IV device connecting to a DDR2 sdram. Now I want to verify if connection between FPGA and DDR2 is OK. So i instantiated a ddr2_controller_with_altmemphy and using the example_top a...
9 years agohttps://alteraforum.com/forum/attachment.php?attachmentid=14028&stc=1
--- Quote Start --- I am using cyclone IV device connecting to a DDR2 sdram. Now I want to verify if connection between FPGA and DDR2 is OK. So i instantiated a ddr2_controller_with_altmemphy and using the example_top as top level entry. After I compile all the project there is no error or timing vilation. But after I download the sof to FPGA, ddr2 calibration fail. After I add the signal in signal_tapII, I can see that afer the seq enter Calculate Read Resynchronization Phase (s_rrp_seek), then the ctl_cal_fail asserted. Here is the signal_tap waveform. Can anyone give me some suggestion. Thanks! https://alteraforum.com/forum/attachment.php?attachmentid=14025&stc=1 --- Quote End ---
