19 years ago
DDR Simulation
Hi Forumees,
Anyone have any experience simulating the verilog model of the DDR SDRAM Controller in modelsim?
I am trying to use the following command -
# compile the encrypted ddr controller in the work
# dir
vlog ${ddrc2_ctl_dir}/_src/ddr_c2_sctl.vo
# re-compile ddr controller in work directory
# this substituting the white-box blocks in
# the database
vlog ${ddrc2_ctl_dir}/_src/ddr_c2_sctl_example_top.v
+libext+.v+.vo -y ${ddrc2_ctl_dir}/_sim
-y ${ddrc2_ctl_dir}/_sim/testbench
-y ${ddrc2_ctl_dir}/_src
-y ${ddr_sdram_megacore_rootdir}/lib
-v $env(QUARTUS_ROOTDIR)/eda/sim_lib/altera_mf.v
-v $env(QUARTUS_ROOTDIR)/eda/sim_lib/220model.v
-v $env(QUARTUS_ROOTDIR)/eda/sim_lib/sgate.v
-v $env(QUARTUS_ROOTDIR)/eda/sim_lib/${sim_family_name}_atoms.v
The command does not have any problems running. But it does not compile the auk_ddr_ctlr module. I do not know why? BTW, I have verified that the tcl variables are pointing to the correct path.
I appreciate any help.
Thank you.
Sanjay
1 Reply
    create a new project and then simulate it will work, its not working in present is due to core is not generated or some conflict in accessing the controller
