18 years agoDDR SDRAM controller Compilations error in Cyclone III
Hi I am trying to build a project with a Nios II/f processor and a DDR SDRAM interface on a Cyclone III FPGA. I have used the preset for the Micron MT46V14M16TG. The controller can only r...
18 years agoHi
I have tried to change some , to a . in the SDC file which seems to fix the "invalid number" errors. I have also tried to comment out the line which causes the previous error, but then I get this error: Critical Warning: Could not find pin of type addrcmd_2t from pattern *ddr_phy_alt_mem_phy_ciii_inst|adc|odt[*].odt_struct|half_rate.addr_pin|auto_generated|ddio_outa[0]|dataout Error: can't use non-numeric string as operand of "+" while executing "expr {$board_skew + $tDS + $WR_DQS_DQ_SETUP_ERROR}" ("foreach" body line 13) invoked from within "foreach dqsgroup $pins(dqsgroup) { set dqspin [lindex $dqsgroup 0] # DQS output clock set dqs_out_clockname "${corename}_ddr_dqsout_${dqspin}" ..." (file "C:/altera/designs/ddr_sdram/ddr_phy_ddr_timing.sdc" line 408) Critical Warning: Read_sdc failed due to errors in the SDC file I am not familiar with the syntax in the SDC file so I have not been able to debug it. Have anybody seen this error before or have a suggestion. I do not get what I am doing wrong. I cannot find the problem in the Errata Sheet for the DDR & DDR2 SDRAM High-Performance Controller so I must be doing something wrong. Best Regards Tom
