19 years agoDDR interface that spans multiple sides of the device
I recently wanted to create a 144-bit DDR2 interface that would span across the top and bottom of a Stratix II device. The Altera MegaWizard allows you to do this but that probably isn't the best wa...
19 years agoI am trying to gather info on the DDR2 IP. It sounds like in order to interface to off-the-shelf DIMM I will need both sides of a Stratix II, is that right? Also is there a limit on the size (depth) of the DIMM?
