8 years agoDDR DQS BANKS 5/6 MAX10 Conflict
In the MAX10M16 the two banks that support DDR memory are bank 5/6. The DQS lines for banks 6 is on pins H11/H12. The DQS lines for banks 5 is on pins L15/K15. If i assign the DQS/DQ on b...
8 years agoI don't understand. You're putting DQS on pin L15 and the error you get is about pin H11? And vice versa?
If you haven't already, in the Pin Planner, go to the View menu and enable the DQ/DQS pin view. That way you can guarantee you are using the optimized and correct pins.
