19 years agoDDR code
Hey I just bought a development board with stratixII. I have a DDR SODIMM memory on my board. I am looking for a VHDL or Verilog code. Is anyone knows a free core so I could to start work wi...
19 years agoForum rules ask that you not "double post" to different Forum sub areas.
Please delete the other one. As to the SDRAM DDR controller. If you are using a Subscription Licensed version of the tools, then there is an DDR SDRAM controller included in the IP set with the tools. Look under the MegaWizard section. IF not, someone here should be ableto help you out with this. Welcome!
