10 years agoHi Kaz,
I got two major peaks in the 16 bit baseband signal. The main peak is 82 dB at 50 KHz and the second peak is 1 dB of DC whereas the noise level is around -100 dB. This 1dB DC is not acceptable. Once I extended the baseband signal to 32 bits, the DC reduced to -71 dB where as the 50KHz still still the same 82 dB. This reduced DC is what I want. I just have no idea why extending the baseband bit width reducing the DC level. I copied this technique from a project without knowing what is the theory behind it. Lee
