AGofs's avatar
AGofs
7 years ago
CycloneV PLL and PLL reconfig simulation
I've generated PLL and PLL_reconfig function with Quartus18.1.
The PLL receives 20 MHz and sends out 25 MHz. I want to change the frequency of the outcoming signal from 25 MHz to 50 MHz.
I'm new with CycloneV and with Quartus18.1
  • AGofs's avatar
    AGofs
    I cannot implement simulation not in Model-Sim nor in Native Link.
    N.B. I've read AN-661. Is it necessary to use AVALON-MM?
  • AGofs's avatar
    AGofs
    Good evening,
    I still have a problem with simulation.
    When I'm trying to simulate Altera PLL and Altera PLL Reconfig Mega-Function via Native Link I'm getting the following error:
  • AGofs's avatar
    AGofs
    # ** Error: (vcom-7) Failed to open design unit file "C:/Alex/my_designs/18_1/PLL_reconfig/PLL_reconfig_001/cycloneV/PLL_RECONFIG_20_25.vho" in read mode.
    # No such file or directory. (errno = ENOENT)
  • AGofs's avatar
    AGofs
    Indeed, there is no such a file. But I have get PLL_20_25.vho for Altera PLL Mega-Function, and PLL_RECONFIG_20_25.hdl for Altera PLL Reconfig Mega-Function. Why file . vho doesn't generate for Altera PLL Reconfig Mega-Function?How can I control it? When I'm trying to simulate the design via Model-Sim10.5B, then no waveform generated by Altera PLL before reconfig and after reconfig.
  • AGofs's avatar
    AGofs
    Hi JwChin,
    thank you for your replay.
    I've simulated my projects (include PLL dynamic phase shift) via Native-Links many times .
    The question is another: in order to simulate via Native-Link , Quartus shall produce xxx .vho file for Altera PLL Reconfig Mega-Function.
    But it doesn't.
    The file xxx.vho Altera PLL Mega-Function has been generated Instead.
    why? Is it wrong? How can simulate frequency reconfiguration on CycloneV?
  • AGofs's avatar
    AGofs
    Hi JwChin,
    I found the way to execute simulation directly via ModelSim-10.1.
    I think, you can close the case. :-)
